September 2023 Windows 11 Version 22H2 Non-Security Optional Preview "C" Release
Started by Corrine, September 26, 2023, 07:37:22 PM
Microsoft released the monthly "C" release preview cumulative updates with non-security improvements and fixes for Windows 11, Version 22H2 today.
Below are some of the many highlights included in the KB5030310 update.  See the KB article for the long list of quality improvements.
Highlights:
  • New! This update introduces websites to the Recommended section of the Start menu. These websites will be personalized for you and come from your browsing history. This gives you quick access to the websites that are important to you. You can remove any website URL from the Recommended section using the shortcut menu. To turn off the feature, go to Settings > Personalization > Start. You can adjust settings for all recommended content on the Start menu on this Settings page. Commercial customers can manage this feature using a policy.
  • This update addresses an issue that affects Microsoft Excel. It stops responding when you try to share a file as a PDF in Outlook.
  • This update addresses an issue that affects the Korean touch keyboard. It completes the first character in the search box on the taskbar. This is not expected.
  • This update addresses an issue that affects the search box tooltip. It does not appear in the correct position.
  • This update addresses an issue that affects the search button. It disappears when you interact with the search flyout box.
  • This update addresses an issue that affects sleep mode. After you resume from sleep, a blank window appears that has the title "Windows Input Experience."
  • This update addresses an issue that affects iCloud Calendar and Contacts. Outlooks fails to properly sync them when you use the iCloud for Windows app. To resume syncing, follow the steps in this Apple Support article.
Update: To get the update, go to Settings > Update & Security > Windows Update. The link to download and install the update can be found in the Optional updates area.  To get the standalone package for this update, go to the Microsoft Update Catalog website.
Windows 11 update history
