Dial-up
Started by Niecarrah, May 04, 2009, 01:51:55 PM
I know very little about Dial-up and how it works, so I need some input.  After having the same IP for years and then changing to a new IP, can this cause problems?  Such as IE Cannot display page,FF page load errors, address not found, and timeouts?
What dial-up Internet Service Provider (ISP) is being used?
Localnet.com is being used now and the prior was 777access.com.
I was hoping I could find something at FL.  Turns out we delisted Localnet some time ago when the setup fee took them over the $10 or less category.  I can see why you are no longer with 777access.com.  When investigating, I see the site has been hacked so delisted it from FL as well.
The reviews aren't all that encouraging either:  http://www.freedomlist.com/forum/comment.php?t=14924&action=read
An example from the forum:  http://www.freedomlist.com/forum/viewtopic.php?t=31466&highlight=localnet
That said (sorry), I don't recall if you are using Windows XP or Windows Vista.  First step is to double-check the setup. It was trickier setting up a dial-up connection on Vista than XP.  The Localnet help pages aren't very helpful:  http://start.localnet.com/help.php
Setup Dialup Details for Windows XP
Instructions for Dial-Up Setup on Windows Vista
LocalNet DNS Settings
Next, check that your firewall or other security software are not blocking.
Basementgeek
Just butting in here, but I have Juno during my first few years on dial up and it worked fine, still works today.  I keep it as a back up incase my DSL goes down. ( Since I use it so little they reduced to 5.00 a month.  When I travel it comes in handy).
BG
Time is a thief- One more today here is one less tomorrow
BG, there are still people who use the old Juno software for their 10 free hours per month!
Basementgeek
Same with Net Zero I believe, 10 hours a month for free.
BG
   :moreevil:    :muahaha:     UGH!  Guess I made a very bad decision, luckily I signed up for monthly(although after reading)could guite possibly be bad anyway. Think I had better start searching for a New ISP as this one sux BIG TIME! Tried to get with Juno free just to compare and have been unable to get it to work(sigh).  I had planned to get the free Juno and see if I would have the same problems as with localnet.  I now suspect I do not need to bother as my doubts have been answered.  Of course I got the same runaround as most of the peeps that rated localnet.  Phone lines, modem driver, etc. so off and looking I shall go!  Will soon be switching to cable, so just wanted something for the interim.  UGH!    :smash:  XP BTW.
We've had decent comments at Freedomlist about Copper.net at Copper.net improves support :: freedomlist.com
The writeup hasn't been updated in some time:  United States - Cheap ISPs - listing for copper.
I suggest searching FL prior to signing up anywhere:  $10 & Under Cheap ISP's - forum :: freedomlist.com.  (Yes, I'm there -- in fact, been there since shortly after FL started in 2000.)
