Windows 11 Insider Release Preview Channel
Started by Corrine, September 23, 2021, 05:53:19 PM
Releasing Windows 11 Builds 22621.3668 and 22631.3668 to the Release Preview Channel
Releasing Windows 11 Builds 22621.3668 and 22631.3668 (KB5037853) to Insiders in the Release Preview Channel on Windows 11, version 22H2 (Build 22621) and version 23H2 (Build 22631).
This update includes the following features and improvements:
  • New! This update adds PC Manager to devices in China.
  • New! This update adds a feature that stops you from accidentally closing the Windows share window. Clicking outside of the window will no longer close it. To close it, select the close button at the upper-right corner. Note this feature might not be available to all users because it will roll out gradually.
  • New! You can now use your mouse to drag files between breadcrumbs in the File Explorer address bar. A breadcrumb shows the path to your current file location in the address bar. For example, there are three breadcrumbs in the path This PC > Windows (C:) > Program Files. Note this feature might not be available to all users because it will roll out gradually.
  • New! You can directly share to specific Microsoft Teams channels and group chats in the Windows share window. To do so, you must sign in using a Microsoft Entra ID. Note this feature might not be available to all users because it will roll out gradually.
  • New! This update adds a page to Settings > Accounts called Linked devices. On it, you can manage your PCs and Xbox consoles. This page only shows on Home and Pro editions when you sign in to Windows using your Microsoft account (MSA).
  • New! This update starts the rollout of the new account manager on the Start menu. When you use a Microsoft account to sign in to Windows, you will get a glance of your account benefits. This feature also makes it easy to manage your account settings. Note this feature might not be available to all users because it will roll out gradually.
  • New! You can now create quick response (QR) codes for webpage URLs and cloud files from the Windows share window. Select the share button in the Microsoft Edge toolbar and choose "Windows share options." Then, you can share the URLs and files across your devices. Note this feature might not be available to all users because it will roll out gradually.
  • New! Windows will now back up many of your sound settings (this includes your sound scheme). This only occurs if you turn on Remember my preferences and select the checkboxes for Personalization and Other Windows settings. To find these, go to Settings > Accounts > Windows backup. Then, you can use the Windows Backup app to restore those settings on a new device.
  • New! You can now send email to yourself from the Windows share window. You will receive the email at the email address that is in your Microsoft account. Note this feature might not be available to all users because it will roll out gradually.
  • New! This update starts the rollout of a the "Add now" button to Settings > Account. When you select it, you can add a recovery email address if you have not added one for your Microsoft account yet. The button only shows if you sign in to your Microsoft account. Note this feature might not be available to all users because it will roll out gradually.
  • New! Starting with this update, you can sign in to your Microsoft account in the Windows Backup app. This app saves backups to your account. Note this feature might not be available to all users because it will roll out gradually.
  • This update addresses a known issue that affects your account profile picture. When you try to change it, you might get an error message. The error code is 0x80070520.
  • This update affects the Antimalware Scan Interface (AMSI) AmsiUtil class. It helps to detect the bypass of the AMSI scan. This update also addresses some long-term issues that expose your device to threats.
  • This update addresses an issue that affects a server after you remove it from a domain. The Get-LocalGroupMember cmdlet returns an exception. This occurs if the local groups contain domain members.
  • This update addresses an issue that affects printers. They do not work as you expect when you use AppContainer or use them in a restricted environment.
  • This update addresses an issue that affects File Explorer. It stops responding when you swipe from a screen edge. This issue occurs after you turn off edge swiping.
  • This update addresses an issue that affects handwriting panels and touch keyboards. They do not appear when you use a pen.
  • This update addresses an issue that displays a hidden window. Its title bar has no content and no client area. This occurs when you share your screen using certain apps.
  • This update addresses an issue that distorts parts of the screen. This occurs when you use a Chromium-based browser to play a video.
  • This update addresses an issue that affects an IPP-over-USB printer. After you delete it, it still appears as not available in Control Panel.
  • This update addresses an issue that affects TWAIN drivers. They might stop responding when you use them in a virtual environment.
  • This update brings Country and Operator Settings Asset (COSA) profiles up to date for certain mobile operators.
  • This update addresses an issue that affects the Host Networking Service (HNS). When the service restarts, load balancer policies are not brought back in the right way.
  • This update addresses an issue that affects the display of a smart card icon. It does not appear when you sign in. This occurs when there are multiple certificates on the smart card.
  • This update addresses an issue that affects Enhanced Fast Reconnect. It fails. This occurs when you use it with third-party remote desktop protocol (RDP) providers.
  • This update addresses an issue that affects File Explorer. It takes up to two minutes to start when you pin a folder that is on a network share to Quick Access. This occurs when you upgrade from Windows 11, version 21H2 to Windows 11, version 22H2.
  • This update addresses an issue that affects an app that supports encrypted email. The app asks you to enter your credentials each time you open an encrypted email. This occurs even after you have entered your PIN at least once.
  • This update addresses an issue that affects a folder context menu. When you choose the command that removes items, the command adds items instead. This occurs when a third-party service implements a sync feature.
  • This update addresses an issue that affects the out-of-box experience (OOBE). It fails to complete. This occurs when you turn on the "Prevent the use of security questions for local accounts" policy.
  • This update addresses an issue that affects Bluetooth Low Energy (LE) Audio headsets. They do not show the option to connect or disconnect.
  • This update addresses an issue that affects the Share button on USB controllers. It might not work with Game Bar.
  • This update addresses an issue that affects Unified Write Filter (UWF) Windows Management Instrumentation (WMI) API calls. Calls to shut down or restart the system throw an access denied exception.
Releasing Windows 11, version 24H2 to the Release Preview Channel
Windows 11, version 24H2 (Build 26100.712) is available in the Release Preview Channel for customers to preview ahead of general availability later this calendar year.
Windows 11, version 24H2* includes a range of new features such as the HDR background support, energy saver, Sudo for Windows, Rust in the Windows kernel, support for Wi-Fi 7, voice clarity and more. It also includes many improvements across Windows. For example, we are introducing a scrollable view of the quick settings flyout from the taskbar, the ability to create 7-zip and TAR archives in File Explorer (in addition to ZIP), and improvements for connecting Bluetooth® Low Energy Audio devices. We will be sharing more details in the coming months on many of the new features and improvements included as part of Windows 11, version 24H2 leading up to general availability. Please note that the new AI features such as Recall announced earlier this week will not be available on your PC after installing this update today as they require a Copilot+ PC. For more information on those new AI features and Copilot+ PCs, see this blog post here.
As part of this update, we're also evolving the Copilot** experience on Windows as an app that will be pinned to the taskbar. This enables users to get the benefits of a traditional app experience, including the ability to resize, move, and snap the window – feedback we've heard from users throughout the preview of Copilot in Windows. This model also allows Microsoft to more agilely develop and optimize the experience based on user feedback. This change will be making is way to Insiders in the Canary, Dev, and Beta Channels shortly.
Windows Insiders in the Release Preview Channel can install Windows 11, version 24H2 via our "seeker" experience in Windows Update. This means if you are an Insider currently in the Release Preview Channel on a PC that meets the Windows 11 hardware requirements, you can go to Settings and Windows Update and choose to download and install Windows 11, version 24H2 if you want. Once you update your PC to Windows 11, version 24H2, you will continue to automatically receive new servicing updates through Windows Update (the typical monthly update process). For instructions on how to join the Windows Insider Program and join your PC to the Release Preview Channel, click here.
Commercial*** customers enrolled in the Windows Insider Program for Business can begin validating Windows 11, version 24H2 on PCs in their organizations. For these customers, the Windows 11, version 24H2 feature update is available through Windows Update for Business (WUfB) and Windows Server Update Service (WSUS). Azure Marketplace will be coming soon. You can learn more about deploying pre-release feature updates using these deployment methods here. Should any issues arise, IT admins in organizations deploying Release Preview updates can request Microsoft Support.
And finally – ISOs will be available later today for Windows 11, version 24H2 via the Windows Insider ISO download page.
*Please note that Cortana, Tips, and WordPad are removed after upgrading to Windows 11, version 24H2. These apps are deprecated.
**Copilot in Windows is being rolled out gradually to Windows Insiders across our global markets. Customers in the European Economic Area will be able to download the Copilot in Windows experience as an app from the Microsoft Store (coming soon).
***We consider a device a commercial device if it is not running the Windows 11 Home edition AND is being managed by an IT administrator (whether via Microsoft Endpoint Manager or other management solution) or has a volume license key or commercial ID or is joined to a domain.
Releasing Windows 11 Builds 22621.3807 and 22631.3807 to the Release Preview Channel
This update includes the following features and improvement (note that items with an asterisk (*) are gradually rolling out):
  • * New! We are advancing the Copilot experience on Windows. It is now pinned to the taskbar and will behave like an app. This gives you the benefits of a typical app experience. For example, you can do things like resize, move, and snap the window.
  • * New! This update adds a new Game Pass recommendation card on the Settings home page. This home page shows on Home and Pro editions when you sign in to Windows using your Microsoft account. The card appears if you actively play games on your PC.
  • * New! The show desktop button is on the taskbar again by default. To change this, right-click the taskbar and choose Taskbar settings. At the lower part of the page, you will find Taskbar behaviors.
  • * New! This update affects File Explorer. You can now create 7-Zip and Tape Archive (TAR) files using the context menu. When you right-click a file, a Compress to item gives you ways to compress a file using tools like gzip, bzip2, and more. There is also a new compression wizard in Additional options. It will help you choose more formats and add details. You can use different types of compression to add many files to archives in other TAR formats. You can also change the compression level and choose the types of data to store in each archive.
  • * New! This update adds support for Emoji 15.1. Windows supports Unicode symbol-like shapes for family groupings. But Windows will keep using people for them. Also, you can choose the right or left facing direction for some people emoji. The new emoji are:
    • Horizontal and vertical head shake
    • Phoenix
    • Lime
    • Brown mushroom
    • Broken chain 48617543
  • * New! You can now copy files from the Windows Share window. Just click the new Copy
  • * New! This update affects OneDrive. You can now use it as a RemoteApp in Azure Virtual Desktop.
  • * This update changes the units for DDR speed from MHz to MT/s.
  • * This update addresses an issue that affects USB devices. Ejecting them using the Safely Remove Hardware option fails. This occurs when Task Manager is open.
  • * This update affects process handles. Task Manager releases them more quickly when it stops a process.
  • * This update makes Task Manager more reliable.
  • * This update affects the sort order of processes in Task Manager. Performance is better when you change the order.
  • * This update makes Task Manager more accessible by improving:
    • Keyboard focus
    • Tab key navigation
    • Text scaling
    • The readout of item names by screen readers
    • High contrast heatmaps and more.
  • * This update makes resizing the Task Manager window easier when you grab the top of its window.
  • This update addresses an issue that affects Group Policy. It fails to detect when a network's speed is slow. Instead, it assumes that a fast link is present.
  • This update addresses an issue that affects Storage Spaces Direct (S2D) and Remote Direct Memory Access (RDMA). When you use them with SMBdirect in your networks, the networks fail. You also lose the ability to manage clusters.
  • This update addresses an issue that affects GPUs. They do not enter the idle state that stops them from consuming power.
  • This update adds the registry key HKLM\Software\Microsoft\Windows\DWM ForceDisableModeChangeAnimation (REG_DWORD). When you set its value to 1 (or a non-zero number), it turns off the display mode change animation. If the value is 0 or the key does not exist, the animation is set to on.
  • This update addresses an issue that affects Snipping Tool. When you use it to record videos on some PCs, the audio has distortions.
  • This update addresses an issue that affects Azure Virtual Desktop sessions. A deadlock stops you from signing in to them.
  • This update addresses an issue that affects the touch keyboard. You cannot use it to enter special characters. This occurs when you use the Japanese 106 keyboard.
UPDATE 6/19: The Copilot changes documented in the release post are now rolling out to Windows Insiders in the Release Preview Channel on Windows 11, version 22H2 and 23H2.
Releasing Windows 11 Build 26100.994 to the Release Preview Channel
  • This update addresses an issue that affects Windows Defender Application Control (WDAC). It fails to verify the policies of some apps.
  • This update addresses an issue that affects WDAC. It reports a certain class of its policies as not active or not authorized.
  • This update addresses an issue that might cause DWM.exe to stop responding.
  • This update addresses an issue that affects Unified Write Filter (UWF). Windows Management Instrumentation (WMI) API calls to shut down or restart a system throws an access denied exception.
  • This update addresses an issue believed to be the underlying cause of some Insiders noticing stutters in some animations recently (dropping frames), particularly with Task View.
Releasing Windows 11 Builds 22621.3951 and 22631.3951 to the Release Preview Channel
Update for Windows Insiders in the Release Preview Channel on Windows 11, version 22H2 (Build 22621) and version 23H2 (Build 22631).
This update includes the following features and improvements (note that items with an asterisk (*) are gradually rolling out) and items bolded in brackets indicate the area of the change being documented:
  • [Notification for Windows Share in China] * New! For nearby sharing to work, Wi-Fi and Bluetooth must be on. If they are off when you turn on nearby sharing, Windows will ask you to allow them to be turned on. This feature might not be available to all users because it will roll out gradually.
  • [File Explorer] * New! When you right-click a tab, you have the choice to duplicate it. This feature might not be available to all users because it will roll out gradually.
  • [Start menu] * New! You can drag apps from the Pinned section of the menu and pin them to the taskbar. This feature might not be available to all users because it will roll out gradually.
  • [File Explorer] * Improves File Explorer reliability, by addressing multiple crashes and hangs. Also, addressed multiple other issues listed as follows. Fixes for these issues might not be available to all users because they will roll out gradually:
    • File Explorer leaks memory leak when interacting with archive folders.
    • The spacing between your desktop icons unexpectedly may become extremely wide.
    • Starting a search from Home in File Explorer may unexpectedly show no results the first time you attempt a search.
    • The address bar dropdown appears unexpectedly sometimes while you are using File Explorer, for example when renaming a file.
    • After a DWM crash, when you open File Explorer it may just show a blank area on top instead of rending the area correctly.
    • File Explorer doesn't react when using the back and forward buttons on a mouse while hovering over the Recommended Files section of Home.
    • The search box doesn't show the correct folder name when you are in Gallery.
    • Pictures in File Explorer Gallery might flash or flicker when scrolling.
    • When using the save dialog, if you try to save a file to Gallery in File Explorer shows an error.
  • [End Task] * Updated the logic for the "End Task" option in the taskbar so that it no longer shows a Not Responding dialog to give confirmation before ending the task. This option is available for users who have enabled End Task under Settings > System > For Developers.
  • [FrameShutdownDelay] The browser ignores its value in the "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" registry key.
  • [Group Policy Preferences Item Level Targeting (ILT) and Local Users and Groups] You cannot choose a group from the target domain for ILT. Also, you cannot choose an account from Local Users and Groups. The forest does not appear. This issue occurs when you deploy multiple forests, and the target domain has a one-way trust with the domain of the admin. This issue affects Enhanced Security Admin Environment (ESAE), Hardened Forests (HF), or Privileged Access Management (PAM) deployments.
  • [Transmission Control Protocol/Internet Protocol (TCPIP)] The issue causes high CPU usage and loss of packets. It also affects TCP connection success rates.
  • [NetAdapterCx module] A system stops responding when large amounts of data travel over Wi-Fi. This issue occurs on devices that have certain wireless network cards.
  • [Universal Print clients] They fail to communicate with the Universal Print service. This affects printing functions. This issue occurs when you turn on Web Proxy Auto Discovery (WPAD).
  • [Print Support App] When you use the app with a USB device, the app stops responding and does not print. This issue also limits the functions of the user interface.
  • [Autopilot] Using it to provision Surface Laptop SE devices fails.
  • [Windows Defender Application Control (WDAC)]
    • A memory leak occurs that might exhaust system memory as time goes by. This issue occurs when you provision a device.
    • WDAC fails to verify the policies of some apps.
  • [Windows Kernel Vulnerable Driver Blocklist file (DriverSiPolicy.p7b)] This update adds to the list of drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • [Bluetooth] You cannot put calls on hold from Bluetooth peripherals.
  • [Windows Backup] Backup sometimes fails. This occurs when a device has an Extensible Firmware Interface (EFI) system partition (ESP).
  • [Cache manager] It might stop responding. This occurs when you use Hyperthreading on Windows Server 2022.
Releasing Windows 11 Build 26100.1297 to the Release Preview Channel
Below is a summary of the new features and improvements included as part of this update separated into two sections: gradual rollout and normal rollout. The bold text within the brackets indicates the item or area of the change documented.
Gradual rollout
These might not be available to all users because they will roll out gradually.
  • [Lock screen] New! Sports, traffic, and finance content will appear along with weather. To turn on this feature, go to Settings > Personalization > Lock screen.
  • [Start menu]
    • New! The new account manager is on the Start menu. When you use a Microsoft account to sign in to Windows, you will get a glance at your account benefits. This feature also makes it easy to manage your account settings.
    • New! You can now also pin apps from the Start menu to the taskbar by dragging and dropping items directly to taskbar from the pinned section in the Start menu.
  • [File Explorer]New! You can now use your mouse to drag files between breadcrumbs in the File Explorer address bar. A breadcrumb shows the path to your current file location in the address bar. For example, there are three breadcrumbs in the path This PC > Windows (C:) > Program Files.
  • [Emoji] New! This update adds support for Emoji 15.1. Windows supports Unicode symbol-like shapes for family groupings. But Windows will keep using people for them. Also, you can choose the right or left facing direction for some people emoji. The new emoji are:
    • Phoenix
    • Lime
    • Brown mushroom
    • Broken chain
  • [Windows Share]
    • New! You can now copy files from the Windows Share window. Just click the new Copy
  • [Windows Backup] New! Windows will now back up many of your sound settings (this includes your sound scheme). This only occurs if you turn on Remember my preferences and select the checkboxes for Personalization and Other Windows settings. To find these, go to Settings > Accounts > Windows backup. Then, you can use the Windows Backup app to restore those settings on a new device.
  • [Settings]
    • New! This update adds a new Game Pass recommendation card on the Settings home page. This home page shows on Home and Pro editions when you sign in to Windows using your Microsoft account. The card appears if you actively play games on your PC.
    • New! This update puts the "Add now" button in Settings > Account. When you select it, you can add a recovery email address if you have not added one for your Microsoft account yet. The button only shows if you sign in to your Microsoft account.
    • New! This update includes updated visuals for the "Rename your PC" and "Change date and time" dialogs to match the Windows 11 visuals.
  • [Task Manager]
    • This update changes the units for DDR speed from MHz to MT/s.
    • This update addresses an issue that affects USB devices. Ejecting them using the Safely Remove Hardware option fails. This occurs when Task Manager is open.
    • This update affects process handles. Task Manager releases them more quickly when it stops a process.
    • This update makes Task Manager more reliable.
    • This update affects the sort order of processes in Task Manager. Performance is better when you change the order.
    • This update makes Task Manager more accessible by improving: Keyboard focus, Tab key navigation, Text scaling, The readout of item names by screen readers, High contrast heatmaps and more.
    • This update makes resizing the Task Manager window easier when you grab the top of its window.
Normal rollout
This update includes the following features and improvements that are rolling out as part of this update. bolded in brackets indicate the area of the change being documented.
  • [PC Manager] New! This update adds PC Manager to devices in China.
  • [Widgets]New! The Widgets icons on the taskbar are no longer pixelated or fuzzy. This update also gives you a larger set of animated icons.
  • [Azure Virtual Desktop] New! You can now use OneDrive as a RemoteApp in Azure Virtual Desktop.
  • [Virtual Filtering Platform (VFP)] New! In Windows nodes, VFP has more support for packet drop collection. This will make it easier to troubleshoot issues.
  • [Windows Server vNext] In the latest build, the cache size display behavior is not what you expect.
  • [Share button] On USB controllers, the button might not work with Game Bar.
  • [Local Security Authority Subsystem Service (LSASS)] It fails at times when you set Field Engineering logging to 5.
  • [NetAdapterCx module] Devices that use certain WLAN cards stop responding.
Releasing Windows 11 Build 22621.4108 and 22631.4108 to the Release Preview Channel
These Builds are to Insiders on Windows 11, version 22H2 (Build 22621) and version 23H2 (Build 22631).
Below is a summary of the new features and improvements included as part of this update separated into two sections: gradual rollout and normal rollout. The bold text within the brackets indicates the item or area of the change being documented.
Gradual rollout
These might not be available to all users because they will roll out gradually. Text bolded in brackets indicate the area of the change being documented.
  • [Windows Share] New! You can now share content to your Android device from the Windows Share window. To do this, you must pair your Android device to your Windows PC. Use the Link to Windows app on your Android device and Phone Link on your PC.
  • [File Explorer]
    • When you press Windows logo key + E, a screen reader might say a pane has focus, or the focus might not be set at all.
    • When you press Ctrl + F, sometimes the search does not start.
    • Keyboard focus sometimes might get lost when you press Shift + Tab.
    • Screen readers do not announce when you open or browse items that are in a breadcrumb of the Open or Save dialog.
    • Screen readers do not announce when you open or browse items in the column header.
  • [Narrator] This update makes scan mode respond quicker. This is especially helpful when you use Microsoft Edge and read large documents. To use scan mode, you must turn on Narrator first (Windows logo key + Ctrl + Enter). Then, turn on scan mode by pressing Caps lock + Spacebar during a Narrator session.
  • [Voice access] You can now dictate the characters that you spell at a faster speed. You also have more editing options for the commands that select, delete, and move within text.
Normal rollout
This update includes the following features and improvements that are rolling out as part of this update. Text bolded in brackets indicates the area of the change being documented.
  • [Input Method Editor (IME)] When a combo box has input focus, a memory leak might occur when you close that window.
  • [Country and Operator Settings Asset] This update brings COSA profiles up to date for certain mobile operators.
  • [Bluetooth] External devices lose their connection when you deploy certain Bluetooth policies.
  • [Bind Filter Driver] Your system might stop responding when it accesses symbolic links.
  • [File Explorer] The navigation pane does not update when you browse folders that are in a shell namespace extension.
  • [Unified Write Filter (UWF) and Microsoft System Center Configuration Manager (SCCM)] An SCCM task to re-enable UWF fails because of a deadlock in UWF. This stops the device from restarting when you expect it.
  • [Hibernate stop error] Your laptop stops responding after you resume it from hibernate. This occurs if you have closed and opened the lid many times.
  • [Microsoft Entra single sign-on (SSO)] The SSO notice that the European Digital Markets Act (DMA) requires prompts too often. This occurs when you authenticate using a certificate. To learn more, see Upcoming changes to Windows single sign-on.
Releasing Windows 11 Build 26100.1586 to the Release Preview Channel
Below is a summary of the new features and improvements included as part of this update for Windows Insiders on Windows 11, version 24H2 (Build 16100).
Normal rollout
  • [Domain Name System (DNS)] A deadlock occurs in the domain controller (DC) when it starts up in the DNS client.
  • [OpenSSH] This update adds a prompt that asks you to confirm when you turn on OpenSSH using the Server Manager UI.
Releasing Windows 11 Build 22621.4247 and 22631.4247 to the Release Preview Channel
This release is to Insiders in the Release Preview Channel on Windows 11, version 24H2 (Build 26100).
Gradual rollout
  • [Start menu] New! The "Sign out" option is now on the account manager when you open the Start menu. To change to a different user, select the ellipses (...). A list of other users appears to make it easier to switch.
  • [Taskbar] New! You can now share local files directly from the search results that appear in the Search box on the taskbar.
  • [Settings] New! The Delivery Optimization Settings page now matches the Windows 11 design. See Settings > Windows Update > Advanced options > Delivery Optimization.
  • [Windows Share] New! This update removes the search box from the Windows Share window.
  • [Lock screen] New! Media controls now show in the lower part of the lock screen at its center when media is playing.
Normal rollout
  • [IE mode] Microsoft Edge sometimes stops responding when you use IE mode.[/b]
  • [Transmission Control Protocol (TCP)] There is inconsistent data between TCP_INFO_v1 and GetPerTcpConnectionEstats
  • . File synchronization services use TCP connection performance analysis tools. This issue affects how accurate those tools are.
  • [Outlook and other encrypted email apps] This issue prompts for your PIN each time you open an encrypted email.
  • Microsoft Defender for Endpoint] Work Folders files fail to sync when Defender for Endpoint is on.
  • [Microsoft Edge] It sometimes stops responding when you use IE mode.
Releasing Windows 11 Build 26100.1876 to the Release Preview Channel
This release is to Insiders in the Release Preview Channel on Windows 11, version 24H2 (Build 16100).
Gradual rollout
  • Taskbar] New! You can now share local files directly from the search results that appear in the Search box on the taskbar.
  • [Settings]
    • New! The Delivery Optimization Settings page now matches the Windows 11 design. See Settings > Windows Update > Advanced options > Delivery Optimization.
    • New! There is a new energy recommendation to turn off high dynamic range (HDR). This helps to conserve energy on devices that have HDR displays. Go to Settings > Power & battery > Energy recommendations.
  • [Battery life] New! When your device's battery power is running low, a pop-up window will appear that asks you to plug in your device. This occurs when the battery level reaches 20% and while Energy Saver is set to "Always On".
Normal rollout
  • [Open Source Software] This update adds attributions to credits.txt files for Rust OSS components.
  • [WebView2 apps] They do not detect input from Xbox 360 and Bluetooth controllers.
Releasing Windows 11 Build 22631.4387 to the Release Preview Channel
Gradual rollout
The following features and improvements might not be available to all users because they will roll out gradually. Text bolded in brackets indicate the area of the change being documented.
  • [Start menu]
    • New! You can directly access content on your mobile device from the Start menu on your PC. Using this feature, you can view your device's battery status and connectivity, access your voice messages, calls, and photos, and pick up where you left off with the latest activities on your device. Only Android users who are already connected using Phone Link can get this feature. iOS support will be coming later. To manage this feature, go to Settings > Personalization > Start.
    • New! "All apps" has the new name, "All."
  • [Gamepad keyboard] New! This update starts the roll out of a new Gamepad keyboard layout for the on-screen keyboard. With it, you can use your Xbox controller to move around the screen and type. Button accelerators are also available; these include the X button for backspace and the Y button for the spacebar. For better movement patterns, the keyboard keys are aligned vertically.
  • [Notifications] New! You can now stop the suggestions to turn off notifications from certain apps. Select the ellipses (...) in the notification and turn it off. You can also go to Settings > System > Notifications and turn it off from there. Look for "Notification Suggestions" in the senders list. An entry will only appear in the list after you receive a notification.
  • [Settings] New! Tailored Experiences is now Personalized offers in the out of box experience (OOBE). You can find it on the Recommendations and offers page. Go to Settings > Privacy & security. Here, you can turn off the setting that sends data about your device to enhance Windows.
Normal rollout
  • [Copilot key settings] New! You can configure the Copilot key on the keyboard. On new devices, the key opens the Copilot app. If you sign in to your account using a Microsoft Entra ID, the key opens the M365 app. You can make the key open a different app or open Search. To do this, go to Settings > Personalization > Text input. To make the key open a different app, the app must be in a signed MSIX package. This ensures that the app meets security and privacy standards to keep you safe. If your PC's keyboard does not have a Copilot key, changing this setting will do nothing.
  • [Battery use] Fixed: A device uses too much battery power while the device is in Modern Standby.
  • [Microsoft Teams] Fixed: The issue stops you from joining Teams meetings when you select an Outlook meeting reminder.
  • [vmswitch] Fixed: A vmswitch triggers a stop error. This occurs when you use Load Balancing and Failover (LBFO) teaming with two virtual switches on a virtual machine (VM). In this case, one virtual switch uses single root Input/Output virtualization (SR-IOV).
  • [Collector sets] Fixed: They do not close properly when an exception occurs during startup or while the set is active. Because of this, the command to stop a collector set stops responding.
  • [Product activation phone numbers] Fixed: This update adds new phone numbers for several regions.
  • [Multi-Function Printer (MFP)] Fixed: When you use a USB cable to connect to it, it prints specific network command text when you do want it to.
  • [Country and Operator Settings Asset (COSA)] Fixed: This update brings profiles up to date for certain mobile operators.
  • [Windows Hello for Business] Fixed: PIN reset does not work when you select the "I forgot my PIN' link on the credentials screen.
  • [Windows Kernel Vulnerable Driver Blocklist file (DriverSiPolicy.p7b)] Fixed: This update adds to the list of drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • [WebView2 apps] Fixed: They do not detect input from Xbox 360 and Bluetooth controllers.
  • [Bluetooth] Fixed: An app stops responding because of a memory leak in a device.
Releasing Windows 11 Build 22631.4534 to the Release Preview Channel
Gradual rollout
  • [Start menu] New! When you right-click apps that you have pinned to the Start menu, jump lists will appear for apps that have jump lists.
  • [Taskbar] New! The system tray shows a shortened date and time. Also, the notification bell icon might not show if you have set the toggle for "Do not disturb" to on. If the bell icon does not show, click the date and time to view your messages in the notification center. To go back to the long form of the date and time, go to Settings > Date and Time. Then turn on the toggle for "Show time and day in the system tray." To show the bell icon, go to Settings > System > Notifications. Turn on the toggle for "Notifications." You can also get to these settings using the context menu. Just right click the system tray clock or bell icon.
  • [Touchscreen] New! This update adds a new section for touchscreen edge gestures. Go to Settings > Bluetooth & Devices > Touch. There, you can choose if you would like to turn off the left or right screen edge touch gesture.
  • [Mouse] New! This update adds the option to turn off enhanced mouse pointer precision to Settings > Bluetooth & Devices > Mouse. There is also a new option to change the direction in which the mouse scrolls.
  • [Task Manager]
    • New! The Disconnect and Logoff dialogs now support dark mode and text scaling.
    • New! The Performance section now shows the type for each disk.
  • [Input Method Editor (IME)] New! After you install this update, the IME toolbar will hide when apps are in full screen mode. This only occurs when the IME toolbar is active, and you type Chinese or Japanese characters.
  • [File Explorer] New! You can share content to an Android device from the context menu in File Explorer and on the desktop. To use this feature, you must install and configure Phone Link on your PC.
  • [IFilters] New! Windows Search runs IFilters in Less Privileged App Containers (LPAC). LPACs are like app containers, but they deny more permissions by default. A process that runs in an LPAC only has access to the resources it needs. The process does not have access to sensitive system components and data. This reduces the potential damage that a compromised process can cause.
  • [Dynamic Lighting Settings page]
    • New! Its page will show a placeholder message when there is no compatible device attached to your computer. Also, the Brightness and Effects controls will be off.
    • New! This update adds the Forward, Backward, Outward, and Inward direction options to the Wave effect. The Gradient effect now has the Forward direction option.
  • [Narrator] New! We have added new functionalities to Narrator scan mode. Skip past links (N') allows you to navigate to the text after a link. This is most helpful when navigating through long emails, news articles, and wiki pages. Jump to lists (L') allows you to quickly access a list on a web page or a document. To try these new features, you need to turn on Narrator first (Win key + Ctrl + Enter), then turn scan mode ON by pressing Caps Lock + Spacebar and finally use the new shortcuts – 'N' and 'L'. Please note that scan mode is 'ON' by default on most web pages (like news articles, wiki page, etc.).
  • [Speech in Windows] New! We have improved our speech-to-text and text-to-speech experience on Windows. Users of Narrator, voice access, live captions, live translations, and voice typing might see a message asking them to update their language files manually. The language files will be released separately through Microsoft Store.
Normal rollout
  • [Motherboard replacement] Fixed: Windows does not activate after you replace a motherboard.
  • [Internet Printing Protocol (IPP) printer] Fixed: Windows stops responding when you use an IPP USB printer.
  • [Bluetooth LE Audio] Fixed: Some devices, like hearing aids, do not stream Bluetooth audio.
